This Product Selection Guide contains information to help select products in the Card Edge Connector Accessories category on DigiKey.com
Card edge connector accessory products are ancillary to or supportive of a variety of card edge connector products. Characterized by their use of a copper contact pattern etched into the periphery of a printed circuit board as one-half of a mating connector pair, accessory products for such connectors include items such as card guides, keying plugs, retention clips, and other products of which many address needs for mechanical fixation of devices incorporating such connectors.
SelectionCharacteristics
Accessory Type: The type, style, or nature of the accessory.
Number of Positions: Indicates the number of distinct conductors presented at a connector’s mating interface.
Features: These are different capabilities or properties of the device such as a gasket or locking feature.
Material: Indicates the material composition of the device.
Color: The dominant color of the device.
ProductExamples
| MFR PART # | MM60-EZH039-B5-R850 |
| DIGIKEY PART # | 670-2276-2-ND - Tape & Reel (TR) |
| MANUFACTURER | JAE Electronics |
| DESCRIPTION | Connector Latch For PCI Express Mini Card |
| MFR PART # | 650025-2 |
| DIGIKEY PART # | A130918-ND |
| MANUFACTURER | TE Connectivity AMP Connectors |
| DESCRIPTION | Connector Keying Plug (Intercontact) For Standard Edge II Series |
| MFR PART # | ERC-031-01-01 |
| DIGIKEY PART # | SAM11066-ND |
| MANUFACTURER | Samtec Inc. |
| DESCRIPTION | Connector Cage For |
| MFR PART # | 423-035-521-102 |
| DIGIKEY PART # | 423-035-521-102-ND |
| MANUFACTURER | EDAC Inc. |
| DESCRIPTION | Connector Connector, Hermaphroditic Contacts For 424 Series |
| MFR PART # | 583691-2 |
| DIGIKEY PART # | 583691-2-ND |
| DESCRIPTION | Connector Spring, Retainer For Twin Leaf Series |
