This Product Selection Guide contains information to help select products in the Card Edge Connector Housings category on DigiKey.com
Card Edge Connector Housings are contactless connectors designed to be used with card-edge circuit boards. The housings have positions ranging from 2 to 350, accommodate card thicknesses from 0.047” to 0.093”, and have pitch dimensions from 0.024” (0.60 mm) to 0.312” (7.92 mm). They come in both free-hanging and panel-mount versions.
SelectionCharacteristics
Card Type: Indicates whether a product is designed to accommodate contacts on one or both sides of a PC board.
Number of Positions: Indicates the number of distinct conductors presented at a connector’s mating interface.
Card Thickness: The nominal circuit board (card) thickness with which a device is compatible.
Pitch: Indicates the center-to-center spacing between adjacent pins.
Features: These are different capabilities or properties of the device such as a flange or latch lock.
Color: The dominant color of the device.
Flange Feature: Describes the design of a part’s mounting flange and the fasteners used in conjunction therewith.
Material - Insulation: Indication of the type of material used in the fabrication of the insulation.
ProductExamples
| MFR PART # | 2008900106 |
| DIGIKEY PART # | WM17663-ND |
| MANUFACTURER | Molex |
| DESCRIPTION | 6 Position Card Edge Connector Housing Natural 0.079" (2.00mm) Free Hanging (In-Line) |
| MFR PART # | 640136-2 |
| DIGIKEY PART # | 640136-2-ND |
| MANUFACTURER | TE Connectivity AMP Connectors |
| DESCRIPTION | 2 Position Card Edge Connector Housing Natural 0.156" (3.96mm) Free Hanging (In-Line) |
| MFR PART # | 1-583861-1 |
| DIGIKEY PART # | A112415-ND |
| DESCRIPTION | 34 Position Card Edge Connector Housing Black 0.100" (2.54mm) Panel Mount |
