This Product Selection Guide contains information to help select products in the D-Sub, D-Shaped Connector Accessories category on DigiKey.com
Products within this family are designed for use with standard D-style and related connectors, and serve ancillary functions such as sealing of a connector assembly, mechanical fixation, avoidance of accidental un-mating, protection of unmated connectors, cable strain relief, keying of connectors to discourage improper connections, facilitating system diagnostics, and others.
SelectionCharacteristics
Accessory Type: The type, style, or nature of the accessory.
Features: These are different capabilities or properties of the device such as antistatic, conductive, or shielded.
Number of Positions: Indicates the number of contacts contained within the connector that the part is designed for use with. Typically the connector itself is not included with purchase of the part.
ProductExamples
| MFR PART # | L17D4K63110 |
| DIGIKEY PART # | L17D4K63110-ND |
| MANUFACTURER | Amphenol ICC (Commercial Products) |
| DESCRIPTION | Connector Cap (Cover), Dust For D-Sub Connectors, Male |
| MFR PART # | SFP67SS09 |
| DIGIKEY PART # | NOR1103-ND |
| MANUFACTURER | NorComp Inc. |
| DESCRIPTION | Connector Sealing Flange For D-Sub Connectors |
| MFR PART # | 16-002190E |
| DIGIKEY PART # | 626-1724-ND |
| MANUFACTURER | Conec |
| DESCRIPTION | Connector Locking Kit For |
