This Product Selection Guide contains information to help select products in the Heavy Duty Connector Accessories category on DigiKey.com
Products in this family are ancillary to or supportive of other interconnect products described as heavy-duty connectors and include various adapters, blanking plugs, cable clamps or glands, coding pins, covers, gaskets, guide bushings and pins, locking latches, and others. In this context, “heavy duty” refers to a relatively specific range of interconnect products that are typically rectangular in format and characterized by features such as cast metal backshells, guide pins, and pin-and-latch retention mechanisms.
SelectionCharacteristics
Accessory Type: The type, style, or nature of the accessory.
Specifications: These are different capabilities or properties of the device such as a circuit breaker, quick connects, or USB port.
Ratings: Minimum performance standards of the device, which are typically set by a third party.
ProductExamples
| MFR PART # | 9140009909 |
| DIGIKEY PART # | 1195-1408-ND |
| MANUFACTURER | HARTING |
| DESCRIPTION | Connector Guide Bushing |
| MFR PART # | 1414353 |
| DIGIKEY PART # | 277-16475-ND |
| MANUFACTURER | Phoenix Contact |
| DESCRIPTION | Connector Dummy Module |
| MFR PART # | T3609210101-000 |
| DIGIKEY PART # | A133867-ND |
| MANUFACTURER | TE Connectivity AMP Connectors |
| DESCRIPTION | Connector Cable Gland |
| MFR PART # | 1963690000 |
| DIGIKEY PART # | 281-6010-ND |
| MANUFACTURER | Weidmüller |
| DESCRIPTION | Connector Cover with Retaining Cord |
