This Product Selection Guide contains information to help select products in the Heavy Duty Connector Assemblies category on DigiKey.com
Heavy Duty connector assemblies are a collection of components (bushings, contacts, housings, inserts) used to assemble the connector. These connectors are known for their large size and for having large current and voltage ratings. The number of positions ranges from 2+ground to 48+ground with the size of the connector ranging from B10 to 32B.
SelectionCharacteristics
Style: Indicates the style and configuration of the device.
Number of Positions: Indicates the number of distinct conductors presented at a connector’s mating interface and the number of electrical contact points present within a connector.
Size: Indicates the standard size the connector meets.
Thread Size: Indicates the thread size of compatible screws and bolts. For more information on screw sizes see Choosing a Screw by the Thread Size.
Termination Style: Describes the shape or standard configuration of a device’s electrical connection(s).
Contents: A general description of what the item comes with.
Includes: A more detailed description of what the item comes with.
ProductExamples
| MFR PART # | 10200040001 |
| DIGIKEY PART # | 1195-5806-ND |
| MANUFACTURER | HARTING |
| DESCRIPTION | 4+Ground Cable and Panel Connector Assembly Top-Hood, Bottom-Base M20 Screw |
| MFR PART # | 1407713 |
| DIGIKEY PART # | 277-16445-ND |
| MANUFACTURER | Phoenix Contact |
| DESCRIPTION | 24+Ground Cable and Panel Connector Assembly Side-Hood, Bottom-Base M32 Push In |
| MFR PART # | 1802740000 |
| DIGIKEY PART # | 1802740000-ND |
| MANUFACTURER | Weidmüller |
| DESCRIPTION | 6+Ground Cable and Panel Connector Assembly Top-Hood, Bottom-Base M20 Screw |
| MFR PART # | 936030090 |
| DIGIKEY PART # | WM24855-ND |
| MANUFACTURER | Molex |
| DESCRIPTION | 24+Ground Cable and Panel Connector Assembly Side-Hood, Bottom-Base M25 Screw |
MediaLinks
Videos
Modular and Pluggable Connection Solutions for the Control Cabinet Walls
Product Training Modules
Introduction to Heavy-Duty Rectangular Connectors - Molex Inc
TechForum
