This Product Selection Guide contains information to help select products in the Modular Connector Jacks category on DigiKey.com
Modular connectors are a series of standardized interconnect products commonly used in wired information and telecommunications networks. Those in this family are receptacles which do not incorporate any magnetic components such as transformers, which are necessary for applications such as Ethernet communications. Plugs and receptacles/jacks which do integrate commonly needed magnetic components are catalogued separately.
SelectionCharacteristics
Number of Positions/Contacts: Indicates connector body size via the number of contact positions available, and the number of said positions that are populated with electrical contacts.
Orientation: The relative direction of the port(s) to the rest of the connector body.
Termination: Selection of termination style used to connect the device to a system, such as press-fit or solder.
Shielding: Whether or not the device possesses an electrically insulating barrier that helps to reduce or eliminate electromagnetic interference, and its type if applicable.
Ratings: Minimum performance standards of the device, which are typically set by a third party.
Features: These are different capabilities or properties of the device such as a boardlock.
LED Color: Describes the color(s) of the indicator LED(s) incorporated in a jack.
Tab Direction: Indicates orientation(s) of a mating plug’s retention tab, when a jack is mounted to the top surface of a horzontal plane.
Contact Material: Indicates the material composition of the contacts.
Contact Finish: Indicates the finish/plating material applied to the contacts.
ProductExamples
| MFR PART # | E5566-Q0LK22-L |
| DIGIKEY PART # | 553-2258-ND |
| MANUFACTURER | Pulse Electronics |
| DESCRIPTION | Jack Modular Connector 6p6c (RJ11, RJ12, RJ14, RJ25) 90° Angle (Right) Unshielded Cat3 |
| MFR PART # | 8808360000 |
| DIGIKEY PART # | 281-3467-ND |
| MANUFACTURER | Weidmüller |
| DESCRIPTION | Jack Modular Connector 8p8c (RJ45, Ethernet) Straight Shielded Cat6 |
| MFR PART # | TM1R-616P44-35S-150M |
| DIGIKEY PART # | H11390-ND |
| MANUFACTURER | Hirose Electric Co Ltd |
| DESCRIPTION | Jack Modular Connector 4p4c (RJ9, RJ10, RJ22) User Selectable Unshielded |
| MFR PART # | 216000-1 |
| DIGIKEY PART # | A123143-ND |
| MANUFACTURER | TE Connectivity AMP Connectors |
| DESCRIPTION | Jack Modular Connector 6p6c (RJ11, RJ12, RJ14, RJ25) Straight Unshielded |
MediaLinks
Videos
EDAC Modular Jacks - Standard
TE Connectivity Industrial RJ45 Jacks
Molex – Modular Jacks and Plugs
Articles
Understanding and Specifying Modular Connectors
Product Training Modules
Modular Jack - Molex Connector Corporation Molex Inc
Blogs
TechForum
Understanding Modular Connectors
RJ Style Connectors
