This Product Selection Guide contains information to help select products in the Machine Vision - Accessories category on DigiKey.com
Machine vision accessories are designed for use with hardware systems that provide imaging-based automatic inspection and analysis for such industrial applications as automatic inspection, process control, and robot guidance. Accessories include adaptors, mounting hardware, battery cells, chargers and compartments, cable assemblies, communications modules, connectors, diffusers, extensions LEDs, lens guides, sensor and filter mounts, filters, stands, control and input devices, and attachments.
SelectionCharacteristics
Accessory Type: The type, style, or nature of the accessory.
ProductExamples
MFR PART # |
ZFV-XMF |
DIGIKEY PART # |
Z10279-ND |
MANUFACTURER |
Omron Automation and Safety |
DESCRIPTION |
ZFV SENSRHEAD MOUNTING BRACKET |
DATASHEET |
Click Here |
MFR PART # |
IVUSLC75-P |
DIGIKEY PART # |
2170-IVUSLC75-P-ND |
MANUFACTURER |
Banner Engineering Corporation |
DESCRIPTION |
IVU LENS COVER 75MM |
DATASHEET |
Click Here |
MFR PART # |
V430-WE-3M |
DIGIKEY PART # |
236-V430-WE-3M-ND |
MANUFACTURER |
DESCRIPTION |
CBL, M12 TO RJ45, 3M |
DATASHEET |
Click Here |
MFR PART # |
G036325000 |
DIGIKEY PART # |
1601-G036325000-ND |
MANUFACTURER |
Excelitas Technologies |
DESCRIPTION |
POLARIZATION FILTER 80 IN ROTARY |
DATASHEET |
Click Here |
If you have any general questions on the specifications for selecting Machine Vision - Accessories, please reply using the button below. If you have questions on specific Machine Vision - Accessories please post those questions in the Automation and Control category.
