This Product Selection Guide contains information to help select products in the Microscopes category on DigiKey.com
Products in the microscope family use optics alone or in conjunction with digital imaging technology to allow objects of small size to be viewed or photographed. Commonly used in electronics contexts for manual visual inspection of components or completed assemblies, they are also used to aid manual assembly of systems or devices incorporating components too small to be viewed conveniently or accurately with the unaided eye.
SelectionCharacteristics
Magnification Range: Indicates the range of optical magnification factors to which a device can be adjusted.
Field of View: The span of distance across a viewed object’s surface that is visible through a device. Varies with magnification setting.
Working Distance: Describes the range of distances between a viewed surface and a device’s objective lens that permit the surface to be brought into focus.
Illumination: The specific classification of the lighting technology used for illumination.
Camera Type: Relates information describing a device’s image sensor as provided by the manufacturer. May include output resolution, optical format, and the sensor technology used.
Interface: Indication of which interface(s) or protocol(s) are used by the device to communicate with other components in the system.
| MFR PART # | TKSZ-LV2 |
| DIGIKEY PART # | 1844-1072-ND |
| MANUFACTURER | O.C. White Co. |
| DESCRIPTION | Microscope, Stereo Zoom (Binocular) 7x ~ 45x LED |
| MFR PART # | SMDPMUSB413 |
| DIGIKEY PART # | SMDPMUSB413-ND |
| MANUFACTURER | Chip Quik Inc. |
| DESCRIPTION | Microscope, Digital 1x ~ 200x LED |
| MFR PART # | 26800B-385 |
| DIGIKEY PART # | 243-1301-ND |
| MANUFACTURER | Aven Tools |
| DESCRIPTION | Microscope, Stereo Zoom (Trinocular) 6.7x ~ 50x Optical, 19x ~ 143x Digital LED, White (60) |
| MFR PART # | 26800C-534 |
| DIGIKEY PART # | 243-1047-ND |
| DESCRIPTION | Microscope, Portable 40x Illuminated |
MediaLinks
Videos
Connect Adapt - Wi-Fi Digital Camera
