This Product Selection Guide contains information to help select products in the Loupes, Magnifiers category on DigiKey.com
Loupes and Magnifiers are equipment designed to help users view small objects by magnifying them through an optical lens. Both handheld and head mounted types are available with magnification ranges from 2x to 20x, and lens sizes from under 0.5 to 2.5 inches.
SelectionCharacteristics
Lens Diameter: Indicates the nominal diameter of the lens.
Magnification Range: Indicates the range of optical magnification factors to which a device can be adjusted.
ProductExamples
| MFR PART # | 26034 |
| DIGIKEY PART # | 243-1021-ND |
| MANUFACTURER | Aven Tools |
| DESCRIPTION | MAGNIFIER EYE LOUPE 10X 1" LENS |
| MFR PART # | 291 |
| DIGIKEY PART # | 1528-2144-ND |
| MANUFACTURER | Adafruit Industries LLC |
| DESCRIPTION | MAGNIFIER STAND 2.5" 4X |
| MFR PART # | 26011 |
| DIGIKEY PART # | 243-1275-ND |
| DESCRIPTION | EYE LOUPE 10X GOLD |
| MFR PART # | 26060 |
| DIGIKEY PART # | 243-26060-ND |
| DESCRIPTION | Magnifier 2.25x, 4x |
| MFR PART # | TOL-09317 |
| DIGIKEY PART # | 1568-1615-ND |
| MANUFACTURER | SparkFun Electronics |
| DESCRIPTION | Magnifier, Stand |
| MFR PART # | 26115 |
| DIGIKEY PART # | 243-26115-ND |
| DESCRIPTION | Magnifier, Headband 1x, 1.5x, 2x, 2.5x, 3.5x |
