This Product Selection Guide contains information to help select products in the Optomechanical category on DigiKey.com
Optomechanical devices are used to position, maintain, or manipulate light through the interaction with mechanical motion.
SelectionCharacteristics
Type: The type, style, or nature of the device.
Length: Indicates the total length of the part.
Outer Diameter: Indicates the outer diameter of the part.
Inner Diameter: Indicates the inner diameter of the part.
Boreholes: Indicates the dimensions of any boreholes in the part.
Adjustment Range: Indicates the amount of allowable adjustability for the part.
ProductExamples
| MFR PART # | G063730000 |
| DIGIKEY PART # | 1601-1247-ND |
| MANUFACTURER | Excelitas Technologies |
| DESCRIPTION | ADJUSTABLE MIRROR INSERT 30 |
| MFR PART # | G061010000 |
| DIGIKEY PART # | 1601-1056-ND |
| DESCRIPTION | MOUNTING PLATE 25 |
| MFR PART # | G061650000 |
| DIGIKEY PART # | 1601-G061650000-ND |
| DESCRIPTION | IRIS DIAPHRAGM C 18, WITH TUBE 2 |
