This Product Selection Guide contains information to help select products in the Ionizer Equipment category on DigiKey.com
The ionizer product family includes both finished goods and component products used to increase the concentration of electrically charged particles in a volume of atmospheric air. This is typically done to reduce the buildup of static electric charge on surfaces in the immediate area, such as workstations for the handling of high-sensitivity electronic components, semiconductor fabrication, and elsewhere.
SelectionCharacteristics
Type: The type and/or style of ionizer being offered.
Voltage - Input: Typically represented by a range, this indicates the low and high voltage limits which one can expect standard operation. Voltages outside this range may damage the device and other system components.
ProductExamples
| MFR PART # | ER-VS02 |
| DIGIKEY PART # | 1110-3424-ND |
| MANUFACTURER | Panasonic Industrial Automation Sales |
| DESCRIPTION | Ionizer Overhead 24VDC |
| MFR PART # | 963E |
| DIGIKEY PART # | SCP298-ND |
| MANUFACTURER | SCS |
| DESCRIPTION | Ionizer Benchtop 100 ~ 240 VAC |
| MFR PART # | 19595 |
| DIGIKEY PART # | 19595-ND |
| MANUFACTURER | Desco |
| DESCRIPTION | Ionizer, Air Gun Benchtop, Portable 100 ~ 240 VAC |
| MFR PART # | MHM306-01 |
| DIGIKEY PART # | 490-14864-ND |
| MANUFACTURER | Murata Power Solutions Inc. |
| DESCRIPTION | Ionizer Chassis Mount 12VDC |
MediaLinks
Videos
Murata MHM Series Ionizer Modules
Panasonic Quick Clips ER-V Static Ionizer Nozzles
TechForum
What is an Ionizer?
