Monitors, Testers
This Product Selection Guide contains information to help select products in the Monitors, Testers category on DigiKey.com
Monitors and Testers are designed to check on the level of static electricity or test devices that monitor the level of static electricity. The types are AC adapter, calibration unit, charge analyzer, equipment monitor, ESD sensor, footwear tester, footwear/wrist strap tester, ground integrity meter, ground integrity/wrist strap tester, static event detector, static indicator, static meter/discharger, surface resistivity meter, tester, verification unit, workstation monitor/tester, and wrist strap/tester.
SelectionCharacteristics
Type: The type of monitoring or testing equipment being offered.
Usage: The manufacturer’s intended usage for the device.
Features: These are different capabilities or properties of the device such as audible alarm, automatic shutoff, or visual alarm.
Power Supply Type: Indicates the battery size and/or nominal AC line voltage supply required to power a device.
ProductExamples
MFR PART # 19350
DIGI-KEY PART # 16-1233-ND
MANUFACTURER Desco
DESCRIPTION TESTER W/S 2 STATE TOUCH NIST
DATASHEET Click Here
MFR PART # ACL 395
DIGI-KEY PART # ST1093-ND
MANUFACTURER ACL Staticide Inc
DESCRIPTION RESIST METER W/CARRYING CASE
MFR PART # 770067
DIGI-KEY PART # 1569-770067-ND
MANUFACTURER SCS
DESCRIPTION WS AWARE MONITOR WITH STANDARD R
MFR PART # SCTEST3
DIGI-KEY PART # 501-SCTEST3-ND
MANUFACTURER Pomona Electronics
DESCRIPTION MULTI-MOUNT CONTINUOUS MONITOR
MediaLinks
Blogs
Dont Let ESD Give You a Shocking Experience
TechForum
ESD Workstation
Establishing an ESD Safe Workspace
If you have any general questions on the specifications for selecting Monitors, Testers, please reply using the button below. If you have questions on specific Monitors, Testers please post those questions in the Anti-Static, ESD, Clean Room Equipment category.
