This Product Selection Guide contains information to help select products in the Anti-Static, ESD Straps, Grounding Cords category on DigiKey.com
Static control grounding cords and straps are devices that connect the wrist or heel of a person to static control materials or ESD (Electro-Static Discharge) alert technology in ESD management systems. They are rated by common resistance values of 100 K?, 1 M? and 2 M? and are selected by material, cord and strap termination, closure type, and length.
SelectionCharacteristics
Type: The product type or intended application.
Cord Type: Indicates the physical style of a grounding cable included with a product, if present.
Cord Termination: Describes connector(s) present on an included grounding cable.
Cord Length: The length of the device’s cord.
Number of Conductors: This is a count of how many conductive paths the device uses.
Strap Closure: The fastening or retention mechanism(s) incorporated in a strap.
Strap Material: The dominant material of the device’s strap.
Strap Termination: The mechanism used for attaching a grounding cable to the strap.
Resistance: The nominal resistance specification for the device.
Color: The dominant color or colors of the device.
Features: These are different capabilities or properties of the device such as expandable or magnetic strap connection.
ProductExamples
| MFR PART # | ESD-WS6-BL |
| DIGIKEY PART # | 2260-ESD-WS6-BL-ND |
| MANUFACTURER | SRA Soldering Products |
| DESCRIPTION | Wrist Strap with Cord 5’ (1.52m) 1 MOhms Black |
| MFR PART # | HGC1M-ECG |
| DIGIKEY PART # | SCP550-ND |
| MANUFACTURER | SCS |
| DESCRIPTION | Heel Strap One Size 1 MOhms Black, Green |
| MFR PART # | 9814 |
| DIGIKEY PART # | 16-1063-ND |
| MANUFACTURER | Desco |
| DESCRIPTION | Cord (For Mats) 15’ (4.57m) Green, Yellow Stripe |
| MFR PART # | 14213 |
| DIGIKEY PART # | 16-1275-ND |
| DESCRIPTION | Cord (For Mats, Wrist Straps) 15’ (4.57m) 1 MOhms Black |
MediaLinks
Videos
SCS - A Minute with Miranda - How to Wear a Wrist Strap
Personnel Grounding ESD Wrist Straps
SCS - 770115 Mat Ground Cord Kit – Installation
Blogs
Dont Let ESD Give You a Shocking Experience
TechForum
ESD Workstation
Establishing an ESD Safe Workspace
