This Product Selection Guide contains information to help select products in the ADCs/DACs - Special Purpose category on DigiKey.com
Products in this family are used for the conversion of information between analog and digital representations and are adapted for specific use cases or integrate additional features or functionality not commonly encountered in general-purpose data converters. Examples include devices that integrate low-noise amplifiers and variable gain stages for ultrasound or automotive radar applications, audio and video-focused products, devices that integrate functionality to indicate measured values on segmented displays, devices integrating galvanic isolation between input and output, and others.
SelectionCharacteristics
Number of Channels: Indicates the number of separate channels able to be manipulated by the device.
Resolution (Bits): The length of the digital word used by a device to represent a continuously variable physical quantity.
Sampling Rate (Per Second): The number of measurements per second the device is able to take.
Data Interface: Indication of which interface(s) or protocol(s) are used by the device to communicate with other components in the system.
Voltage Supply Source: A general description of how the device is nominally powered.
Voltage - Supply: Typically represented by a range, this indicates the low and high voltage limits which one can expect standard operation. Voltages outside this range may damage the device and other system components.
Operating Temperature: Recommended operating temperature, typically given in a range or as a maximum. Exceeding these temperatures may affect performance or damage the device and/or other system components.
ProductExamples
| MFR PART # | WM8524CGEDT/R |
| DIGIKEY PART # | WM8524CGEDT/RTR-ND - Tape & Reel (TR) |
| MANUFACTURER | Cirrus Logic Inc. |
| DESCRIPTION | DAC, Audio 24 b 192k I²S 16-TSSOP |
| MFR PART # | AK5704EN |
| DIGIKEY PART # | 974-AK5704ENTR-ND - Tape & Reel (TR) |
| MANUFACTURER | Asahi Kasei Microdevices/AKM |
| DESCRIPTION | ADC, MIC-AMP 32 b 192k I²S 28-QFN (4x4) |
| MFR PART # | HCPL-7860-500E |
| DIGIKEY PART # | 516-4226-2-ND - Tape & Reel (TR) |
| MANUFACTURER | Broadcom Limited |
| DESCRIPTION | Isolated Module 12 b 8-SMD |
MediaLinks
Articles
Analog Basics – Part 1: SAR Analog-to-Digital Converters
Product Training Modules
Analog to Digital Converter
Blogs
Basics of ADC/DAC
