This Product Selection Guide contains information to help select products in the Audio Special Purpose category on DigiKey.com
Special Purpose audio devices are semiconductors designed to filter, drive, amplify, convert, and interface audio signals. The characteristics are function, applications, number of channels, interface, voltage, and specifications. The applications include audio systems, automotive audio, consumer audio, musical instruments, professional audio, communication systems, telecommunication systems, digital audio, driver, pre-amplifier, signal mixing, signal processing, voice trigger solution, or 10 Base-T.
SelectionCharacteristics
Function: Describes the main function or usage of the circuit.
Applications: Application is the type of equipment or environment the device will be used in, they are tested and typically rated by a third party to ensure certain minimum standards for the application they are intended for. You could use one with a higher rating, but you cannot use one with a lower rating as it will fail in that application. For example, you could use a medically rated device to replace a commercial device, but you cannot replace the medical device with the commercial device.
Number of Channels: The number of output signal paths (channels) supported by the device.
Interface: Indication of which interface(s) or protocol(s) are used by the device to communicate with other components in the system.
Voltage - Supply: Typically represented by a range, this indicates the low and high voltage limits which one can expect standard operation. Voltages outside this range may damage the device and other system components.
Specifications: Describes specifications of the device’s primary function.
Package / Case: Indicates the type of protective case used on an electronic component to allow easy handling, installation, and protection. This selection was determined to be the closest industry standard applicable to the suppliers device packaging. Typically it is best to check the actual dimensions from the datasheet rather than depend on this terminology when designing your circuit.
ProductExamples
| MFR PART # | Rohm Semiconductor |
| DIGIKEY PART # | BD37513FS-E2TR-ND - Tape & Reel (TR) |
| MANUFACTURER | BD37513FS-E2 |
| DESCRIPTION | Audio Audio Tone Processor 4 Channel 20-SSOP-A |
| MFR PART # | Texas Instruments |
| DIGIKEY PART # | 296-17962-5-ND |
| MANUFACTURER | PGA2320IDW |
| DESCRIPTION | Audio Volume Control 2 Channel 16-SOIC |
Schematic Symbol
MediaLinks
Videos
Getting Started with the Audio Player for the SK S7G2
Audio
Articles
Choosing the Right MCU for Your Audio Application
How to Efficiently Decode and Play Audio Files in Embedded Systems
How to Select and Use an Audio Codec and Microcontroller for Embedded Audio Feedback Files
Audio
Product Training Modules
AVR UC3 Audio Application Microchip Technology
Class D Audio Amplifiers NXP Semiconductors
USB/MP3 Audio Media Decoder ROHM Semiconductor
Audio
TechForum
Audio codec AK7755 interface for USB audio application
Getting Started with a custom Audio Cape
Audio
Blogs
Audio Processing with STM32
Audio
