This Product Selection Guide contains information to help select products in the Analog Switches - Special Purpose category on DigiKey.com
Special Purpose Analog Switches route analog signals via a solid-state device. The differentiator in this family is that these Analog switches target a specific application, and as such have distinguishing features not typically found in general purpose Analog switches.
SelectionCharacteristics
Applications: Application is the type of equipment or environment the device will be used in, typically they are tested and rated by a third party to ensure certain minimum standards for the application they are intended for.
Multiplexer/Demultiplexer Circuit: Indicates channel configuration(s) of the switching mechanism(s) in a device.
Switch Circuit: Refers to the specific operation or behavior of a switch, indicating the primary purpose or mode of operation. For more information please see: Switch Basics, Examples of Pole and Throw
Number of Channels: Defines the number of channels for the switch.
On-State Resistance (Max): Characterizes the maximum resistance of a controlled/switched current path through a device when that path is closed, connected, or “on.” Measured under manufacturer-defined test conditions.
Voltage - Supply, Single (V+): Describes permissible supply voltage span when a single supply voltage is used. Voltages outside this range may damage the device and other system components.
Voltage - Supply, Dual (V±): Describes permissible supply voltage span when dual supplies (positive and negative with respect to a common reference or “ground”) are used. Voltages outside this range may damage the device and other system components.
-3db Bandwidth: Characterizes a device’s high-frequency signal limitations, indicating the frequency at which signals passed through a device would be attenuated by 3dB.
Features: These are different capabilities or properties of the device such as buffered or configurable.
ProductExamples
| MFR PART # | TC7USB40MU,LF(S2E |
| DIGIKEY PART # | 264-TC7USB40MU,LF(S2ETR-ND - Tape & Reel (TR) |
| MANUFACTURER | Toshiba Semiconductor and Storage |
| DESCRIPTION | IC USB SWITCH SPDT DUAL 10UQFN |
| MFR PART # | FSUSB42MUX |
| DIGIKEY PART # | FSUSB42MUXTR-ND - Tape & Reel (TR) |
| MANUFACTURER | onsemi |
| DESCRIPTION | IC USB SWITCH DPDT 10MSOP |
| MFR PART # | FSA646AUCX |
| DIGIKEY PART # | 488-FSA646AUCXTR-ND - Tape & Reel (TR) |
| DESCRIPTION | IC SWITCH SPDT 36-WLCSP |
| MFR PART # | PEX8724-CA80BC G |
| DIGIKEY PART # | 516-3405-ND |
| MANUFACTURER | Broadcom Limited |
| DESCRIPTION | IC PCI EXPRESS SWITCH 324FCBGA |
MediaLinks
Articles
Analog Switches and Muxes for Sensor Arrays
CMOS Analog Simplify Audio/Video Switching
Analog Switches Multiplexers Can Share Resources
More Articles on Analog Switches
Product Training Modules
Analog Switches - NXP Semiconductors
Analog Switches: Operation/Application - Nexperia
Analog Switch Solutions - TI
More Product Training Modules on Analog Switches
TechForum
Audio Amplifiers/Analog Switches – What is Depop?
More TechForum posts on Analog Switches
