This Product Selection Guide contains information to help select products in the Lockers, Storage Cabinets and Accessories category on DigiKey.com
SelectionCharacteristics
Type: The type, style, or nature of the accessory.
Construction: Indicates the device’s primary construction materials and/or methods.
Bin Quantity: Indicates the number of individual bins or containers available within the device.
Shelf Quantity: Indicates the number of horizontal shelf tiers available within the device.
Height (Inches): Indicates the overall height of the device.
Width (Inches): Indicates the overall width of the device.
Depth (Inches): Indicates the overall depth of the device.
Material: Indicates the material composition of the device.
Color: The dominant color of the device.
Capacity (Pounds): Indicates the maximum weight capacity the device can bear without damage, across all of its shelves/compartments.
Wheel Type: Indicates which style and/or material of wheel the device includes with its construction, if any.
UNSPSC Code: The United Nations Standard Products and Services Code for the device, if it has one.
ProductExamples
| MFR PART # | USV1258-3PT-GL |
| DIGIKEY PART # | 3539-USV1258-3PT-GL-ND |
| MANUFACTURER | Global Industrial |
| DESCRIPTION | Tan Locker |
| DATASHEET | Not Yet Available |
| MFR PART # | 15201212001000 |
| DIGIKEY PART # | 3539-15201212001000-ND |
| MANUFACTURER | Remco Plastics |
| DESCRIPTION | BOX LOCKER FOR 6-TIER, PLASTIC, |
| MFR PART # | 001-95 |
| DIGIKEY PART # | 3539-001-95-ND |
| MANUFACTURER | Durham Mfg. |
| DESCRIPTION | Gray Steel Compartment Bin Cabinet |
| MFR PART # | 493143GY |
| DIGIKEY PART # | 3539-493143GY-ND |
| MANUFACTURER | IndustrialSupplies.com |
| DESCRIPTION | Gray Steel Locker |
