This Product Selection Guide contains information to help select products in the Bumpers, Feet, Pads, Grips category on DigiKey.com
Bumpers, feet, pads, and grips are hardware accessories designed to add surface protection and cushion features to boxes and devices. They are selected by material such as rubber, plastic, and nylon, hardness, thickness, size, color, and shape. Mounting types include adhesive, push-in, rivet, screw, snap, or threaded stud. Available in bulk, roll, sheet, and strip.
SelectionCharacteristics
Type: The type, style, or nature of the device.
Shape: Identifies the geometrical figure of the device.
Color: The dominant color of the device.
Size/Dimension: The physical dimensions of the device. Typically diameter or length and width.
Thickness: Indicates the overall height of the part.
Material: Indicates the material composition of the device.
Hardness: Indicates typical material hardness and measurement scale. Higher numbers within a scale correlate to harder/firmer material.
Form: Indicates the manufacturer standard packaging.
ProductExamples
| MFR PART # | 2544 |
| DIGIKEY PART # | 3720-2544-ND |
| MANUFACTURER | Heyco Products Corporation |
| DESCRIPTION | FSD 24-31-32 BLACK |
| MFR PART # | SJ5308 |
| DIGIKEY PART # | 3M157537-ND |
| MANUFACTURER | 3M |
| DESCRIPTION | BUMPER SQUARE 0.5"L X 0.5"W CLR |
| MFR PART # | 723 |
| DIGIKEY PART # | 36-723-ND |
| MANUFACTURER | Keystone Electronics |
| DESCRIPTION | BUMPER CYLIN 0.937" MLD WASHER |
