This Product Selection Guide contains information to help select products in the Clips, Hangers, Hooks category on DigiKey.com
Clips, hangers, strips and hooks are utility hardware devices that attach to a surface by adhesion or a fastener to establish a secure mounting point or provide retaining pressure or friction. They are selectable by size such as jumbo, large, micro, mini and small, and by finish including black, bronze, clear, green, nickel, silver and white. Many adhesive types are designed to be removable without surface damage or residue.
SelectionCharacteristics
Type: The type, style, or nature of the device.
Color: The dominant color of the device.
Size: Indicates the size category the manufacturer lists the device as being a part of, such as mini, medium, or jumbo.
Size/Dimension: The physical dimensions of the device. Typically listed as length by width.
ProductExamples
MFR PART # | 17067ES |
DIGIKEY PART # | 19-17067ES-ND |
MANUFACTURER | 3M |
DESCRIPTION | SMALL WIRE HOOK 3 HOOKS 4 STRIPS |
DATASHEET | Click Here |
MFR PART # | 3PHKITM-10ES |
DIGIKEY PART # | 19-3PHKITM-10ES-ND |
MANUFACTURER | 3M |
DESCRIPTION | CLAW VARITY PACK 15 25 45 LBS |
MFR PART # | RF4721 |
DIGIKEY PART # | RF4721-ND |
MANUFACTURER | 3M |
DESCRIPTION | SCOTCH GENERAL PURPOSE FASTENERS |
MediaLinks
TechForum
FAQ - Command Strips, Hooks, and Mounts by 3M
