This Product Selection Guide contains information to help select products in the Coaxial Connector (RF) Accessories category on DigiKey.com
Coaxial connector accessories are items used with coaxial cable connector systems, which serve ancillary functions such as sealing of a connector assembly, mechanical fixation, avoidance of accidental un-mating, protection of un-mated connectors, cable strain relief, and others.
SelectionCharacteristics
Connector Style: Indicates a specific type of connector with which the accessory is designed to be used.
Accessory Type: The type, style, or nature of the accessory.
Body Material: Indicates the material composition of the device.
Body Finish: Indicates the finish/plating material applied to the device.
Features: These are different capabilities or properties of the device such as a chain, latch lock, or IP rating.
IP Ratings
IP (Ingress Protection) ratings such as (IP20, IP65, IP67, etc.) define how likely water and dirt will get into the system. The first number represents dirt and solid contaminants while the second represents water and liquids.
| Solids | Liquids | |
| 1 | Protected against solids larger than 50mm. | Protected against vertically falling drops of water. Limited Ingress permitted. |
| 2 | Protected against solids larger than 12.5mm. | Protected against vertically falling drops of water with the enclosure tilted up to 15 degrees from vertical. Limited ingress permitted. |
| 3 | Protected against solids larger than 2.5mm. | Protected against spraying water up to 60 degrees from vertical. Limited ingress permitted for 3 minutes. |
| 4 | Protected against solids larger than 1mm. | Protected against water splashed from any direction. Limited ingress permitted. |
| 5 | Protected against dust. Limited ingress of dust permitted. | Will not affect operation of equipment 2-8 hours. Protected against jets of water. Limited ingress permitted. |
| 6 | Dust tight. No ingress of dust 2-8 hours. | Protected against powerful jets of water. Limited ingress permitted. |
| 7 | ______________________ | Protected against the effects of immersion in 15cm-1m for 30 minutes. |
| 8 | ______________________ | Continuous immersion in water up to 3m for long periods of time. |
| 9 | ______________________ | Protected against high pressure jets of hot water. (30 seconds) |
| 9K | ______________________ | Protected against high pressure jets of hot water. (2 minutes) |
Color: The dominant color of the device.
ProductExamples
| MFR PART # | 9311-60221 |
| DIGIKEY PART # | 1678-9311-60221-ND |
| MANUFACTURER | Amphenol SV Microwave |
| DESCRIPTION | Connector Housing Module For |
| MFR PART # | MM126036 |
| DIGIKEY PART # | 490-4983-ND |
| MANUFACTURER | Murata Electronics |
| DESCRIPTION | Connector Measurement Probe For SWD and SWF Connectors |
| MFR PART # | RFI45-13-D3 |
| DIGIKEY PART # | 1097-1265-ND |
| MANUFACTURER | Cinch Connectivity Solutions Trompeter |
| DESCRIPTION | Connector Cap (Cover), Dust For TNC Bulkhead Jacks |
