This Product Selection Guide contains information to help select products in the Modular Connector Accessories category on DigiKey.com
Modular connectors are a series of standardized interconnect products commonly used in wired information and telecommunications networks. Accessory products for such connectors include items such as backshells, caps, covers, seals, mounting and fixation hardware, protective devices, and a variety of other items ancillary to or supportive of their use, either as commonly encountered or in modified form to facilitate their use in unconventional situations.
SelectionCharacteristics
Accessory Type: The type, style, or nature of the accessory.
Features: These are different capabilities or properties of the device such as a cable clamp, cover, or IP ratings.
IP Ratings
IP (Ingress Protection) ratings such as (IP20, IP65, IP67, etc.) define how likely water and dirt will get into the system. The first number represents dirt and solid contaminants while the second represents water and liquids.
| Solids | Liquids | |
| 1 | Protected against solids larger than 50mm. | Protected against vertically falling drops of water. Limited Ingress permitted. |
| 2 | Protected against solids larger than 12.5mm. | Protected against vertically falling drops of water with the enclosure tilted up to 15 degrees from vertical. Limited ingress permitted. |
| 3 | Protected against solids larger than 2.5mm. | Protected against spraying water up to 60 degrees from vertical. Limited ingress permitted for 3 minutes. |
| 4 | Protected against solids larger than 1mm. | Protected against water splashed from any direction. Limited ingress permitted. |
| 5 | Protected against dust. Limited ingress of dust permitted. | Will not affect operation of equipment 2-8 hours. Protected against jets of water. Limited ingress permitted. |
| 6 | Dust tight. No ingress of dust 2-8 hours. | Protected against powerful jets of water. Limited ingress permitted. |
| 7 | ______________________ | Protected against the effects of immersion in 15cm-1m for 30 minutes. |
| 8 | ______________________ | Continuous immersion in water up to 3m for long periods of time. |
| 9 | ______________________ | Protected against high pressure jets of hot water. (30 seconds) |
| 9K | ______________________ | Protected against high pressure jets of hot water. (2 minutes) |
Color: The dominant color of the device.
ProductExamples
| MFR PART # | CP-RJ45 |
| DIGIKEY PART # | RP780-ND |
| MANUFACTURER | Essentra Components |
| DESCRIPTION | Connector Cap (Cover), Dust For RJ45 Connectors |
| MFR PART # | 988P |
| DIGIKEY PART # | 36-988P-ND |
| MANUFACTURER | Keystone Electronics |
| DESCRIPTION | Connector Cap (Cover) For RJ45 Connectors |
| MFR PART # | 17-10002 |
| DIGIKEY PART # | 626-1360-ND |
| MANUFACTURER | Conec |
| MFR PART # | RJF54402JE |
| DIGIKEY PART # | APC1002-ND |
| MANUFACTURER | Amphenol Socapex |
| DESCRIPTION | Connector Gasket, Seal For RJF 544 Series Receptacle |
