This Product Selection Guide contains information to help select products in the Telecom category on DigiKey.com
Telecom interface integrated circuits (ICs) provide specific functionality and control in communication network interfacing such as Ethernet switching, line drivers, ISDN, amplifiers, channel extenders, digital phase-locked loops, DTMF, tone generators and decoders, echo cancelation, detectors and generators, DDA, phone line monitors, and calling line identifiers.
SelectionCharacteristics
Function: Indicates the device’s primary purpose within a circuit.
Interface: Indication of which interface(s) or protocol(s) are used by the device to communicate with other components in the system.
Number of Circuits: Indicates the number of circuits of similar functions that are implemented within the device.
Voltage - Supply: Typically represented by a range, this indicates the low and high voltage limits which one can expect standard operation. Voltages outside this range may damage the device and other system components.
Current - Supply: This represents the maximum current to which a device will meet its given specifications. Exceeding this current may damage the device and/or other system components.
Power (Watts): Typically this represents the maximum power rating to which a device will meet its given specifications. Exceeding this power rating may damage the device and other system components.
ProductExamples
| MFR PART # | CPC5712UTR |
| DIGIKEY PART # | CLA303TR-ND - Tape & Reel (TR) |
| MANUFACTURER | Littelfuse Inc. |
| DESCRIPTION | Telecom IC Phone Line Monitor with Detectors (PLMD) 16-SOP |
| MFR PART # | VSC8531XMW-05 |
| DIGIKEY PART # | VSC8531XMW-05-ND |
| MANUFACTURER | Microchip Technology |
| DESCRIPTION | Telecom IC Ethernet 48-QFN (6x6) |
| MFR PART # | DS3680N |
| DIGIKEY PART # | 296-9485-5-ND |
| MANUFACTURER | Texas Instruments |
| DESCRIPTION | Telecom IC Driver 14-PDIP |
| MFR PART # | DS21348T+ |
| DIGIKEY PART # | DS21348T±ND |
| MANUFACTURER | Analog Devices Inc./Maxim Integrated |
| DESCRIPTION | Telecom IC Line Interface Unit (LIU) 44-TQFP (10x10) |
MediaLinks
Videos
Telecom Videos
Articles
Developing Modern Telecom Applications
The Evolving Face of Telecom Processing
Efficient Telecom Power Supplies
More Articles on Telecom
Product Training Modules
Product Training Modules on Telecom
Blogs
Blogs on Telecom
TechForum
TechForum Posts on Telecom
