This Product Selection Guide contains information to help select products in the Specialized category on DigiKey.com
Products in this family provide functions needed to interconnect an information source/sink to a sensor, transducer, actuator, transfer medium, or other such endpoint in a wide variety of esoteric or narrowly focused applications. Examples include automotive airbag drivers, body control and infotainment busses, adaptive cable equalizers, smart cards, and many others.
SelectionCharacteristics
Applications: Application is the type of equipment or environment the device will be used in, typically they are tested and rated by a third party to ensure certain minimum standards for the application they are intended for.
Interface: Indication of which interface(s) or protocol(s) are used by the device to communicate with other components in the system.
Voltage - Supply: Typically represented by a range, this indicates the low and high voltage limits which one can expect standard operation. Voltages outside this range may damage the device and other system components.
ProductExamples
| MFR PART # | MAX16054AZT+T |
| DIGIKEY PART # | MAX16054AZT+TTR-ND - Tape & Reel (TR) |
| MANUFACTURER | Analog Devices Inc./Maxim Integrated |
| DESCRIPTION | PDA’s, Portable Audio/Video, Smartphones Interface TSOT-23-6 |
| MFR PART # | PI3PCIE3242AZLEX |
| DIGIKEY PART # | PI3PCIE3242AZLEXDITR-ND - Tape & Reel (TR) |
| MANUFACTURER | Diodes Incorporated |
| DESCRIPTION | PCIe Interface 30-TQFN (2.5x4.5) |
| MFR PART # | Z84C2010PEG |
| DIGIKEY PART # | 269-5058-ND |
| MANUFACTURER | Zilog |
| DESCRIPTION | I/O Controller Interface 40-PDIP |
| MFR PART # | SEC1110I-A5-02 |
| DIGIKEY PART # | SEC1110I-A5-02-ND |
| MANUFACTURER | Microchip Technology |
| DESCRIPTION | Smart Card Interface 16-QFN (5x5) |
| MFR PART # | PI7C9X2G304SLBFDEX |
| DIGIKEY PART # | PI7C9X2G304SLBFDEXDITR-ND - Tape & Reel (TR) |
| DESCRIPTION | Packet Switch, 3-Port/4-Lane Interface 128-LQFP (14x14) |
| MFR PART # | LTC6820IMS#PBF |
| DIGIKEY PART # | 505-LTC6820IMS#PBF-ND |
| MANUFACTURER | Analog Devices Inc. |
| DESCRIPTION | Isolated Communications Interface Interface 16-MSOP |
