This Product Selection Guide contains information to help select products in the Sensor and Detector Interfaces category on DigiKey.com
Products in this family perform signal conditioning, data conversion, stimulus generation, and/or a variety of other functions needed to connect a sensor or transducer mechanism to a host device. Examples include controllers for CCD image sensors, current transmitters for 4-20 mA interface and similar applications, ultrasound transducer front-ends, wheatstone bridge interfaces, and others.
SelectionCharacteristics
DigiKey Programmable: For verified products, DigiKey can program/flash your compiled code or confirguration variables prior to shipping. For unverified products, please enquire with ProgCent.Techs@digikey.com.
Input Type: Identifies the type of input signal the device was designed for use with.
Output Type: Identifies the type of signal output by the device.
Current - Supply: This rating indicates the nominal amount of current you would expect the device to draw during normal operation.
ProductExamples
| MFR PART # | NCS36000DRG |
| DIGIKEY PART # | NCS36000DRGOSTR-ND - Tape & Reel (TR) |
| MANUFACTURER | onsemi |
| DESCRIPTION | IC PIR DETECTOR CTLR 14SOIC |
| MFR PART # | MAX14626ETT+T |
| DIGIKEY PART # | MAX14626ETT+TTR-ND - Tape & Reel (TR) |
| MANUFACTURER | Analog Devices Inc./Maxim Integrated |
| DESCRIPTION | IC CURR LOOP PROT 4-20MA 6TDFN |
| MFR PART # | AD694JNZ |
| DIGIKEY PART # | AD694JNZ-ND |
| MANUFACTURER | Analog Devices Inc. |
| DESCRIPTION | IC TRANSMITTER 4-20MA 16-DIP |
