This Product Selection Guide contains information to help select products in the Modules category on DigiKey.com
Terminal block interface module products serve an interconnect function in a branching or breakout capacity, providing a convenient means of transitioning from a high density interconnect format such as a D-sub or rectangular connector to one of lower density that is more easily serviced, such as a set of terminal blocks. This can simplify installation and maintenance tasks in industrial control systems by allowing the use of high density cabling between a control device and the point at which the signals need to be made accessible for service or installation.
SelectionCharacteristics
Protocol: Enumerates the communications protocols and/or standard interfaces that a device supports or implements.
Function: Indicates the use case of the device.
Interface: Indication of which interface(s) are used by the device to communicate with other components in the system.
Standards: Enumerates protocol, format, form factor, or similar standards with which a device conforms.
Voltage - Supply: Typically this rating indicates the nominal amount of voltage you would expect the device to draw during normal operation.
Current - Supply: Typically this rating indicates the nominal amount of current you would expect the device to draw during normal operation.
ProductExamples
| MFR PART # | DEV-09716 |
| DIGIKEY PART # | 1568-1103-ND |
| MANUFACTURER | SparkFun Electronics |
| DESCRIPTION | BRIDGE USB 2.0 MODULE |
| MFR PART # | WIZ850IO |
| DIGIKEY PART # | 1278-1043-ND |
| MANUFACTURER | WIZnet |
| DESCRIPTION | ETHERNT 10/100 BASE-T/TX PHY MOD |
| MFR PART # | FT2232H-56Q MINI MDL |
| DIGIKEY PART # | 768-1278-ND |
| MANUFACTURER | FTDI, Future Technology Devices International Ltd |
| DESCRIPTION | USB Controller USB 2.0 FIFO Interface Module |
| MFR PART # | ISL99227HRZ-T7A |
| DIGIKEY PART # | 20-ISL99227HRZ-T7ATR-ND - Tape & Reel (TR) |
| MANUFACTURER | Renesas Electronics Corporation |
| DESCRIPTION | Controller PWM Interface 32-PQFN (5x5) |
