This Product Selection Guide contains information to help select products in the Modems - ICs and Modules category on DigiKey.com
Interface Modem ICs and Modules are devices that modulate or demodulate an incoming signals from a telephone or cable lines to be transmitted from a computer. The data format is ASK, FSK, Bell 202, HART, V.21, V.22, V.23, V.32, V.34, V.90, and V.92 with Baud rates of selectable, 300, 1.2k, 1.8k, 2.4k, 4.8k, 9.6k, 14.4k, 19.2k, 20k, 33.6k, 38.4k, 56k, and 200k having a mounting type of socket, surface mount, or through hole.
SelectionCharacteristics
Data Format: Indicates the basic set(s) of connection standards supported by a device; has implications for achievable data transfer rates.
Baud Rates: Indicates the rate at which the number of signal elements or changes to the signal occurs per second when it passes through a transmission medium
Voltage - Supply: Typically this rating indicates the nominal amount of voltage you would expect the device to draw during normal operation.
ProductExamples
| MFR PART # | MX604TN-TR1K |
| DIGIKEY PART # | 2032-MX604TN-TR1KTR-ND - Tape & Reel (TR) |
| MANUFACTURER | CML Microcircuits |
| DESCRIPTION | V.23 COMPATIBLE MODEM |
| MFR PART # | AD5700ACPZ-RL7 |
| DIGIKEY PART # | 505-AD5700ACPZ-RL7TR-ND - Tape & Reel (TR) |
| MANUFACTURER | Analog Devices Inc. |
| DESCRIPTION | IC HART MODEM LP 24LFCSP |
| MFR PART # | Z0220516PSG1961 |
| DIGIKEY PART # | Z0220516PSG1961-ND |
| MANUFACTURER | Zilog |
| DESCRIPTION | IC MODEM CTRL 86E34 28-DIP |
MediaLinks
Videos
Videos on Modems
Articles
Cellular Modems for M2M Systems
Differentiating IoT and M2M Design Characteristics
Welcome to the Wireless Menagerie RF Bands and Protocol Choices for Embedded Developers
More Articles on Modems
Blogs
IoT Available to Everyone
Siretta Cellular Signal Strength Analyzers
More Blogs on Modems
TechForum
TechForum posts on Modems
