This Product Selection Guide contains information to help select products in the Specialized ICs category on DigiKey.com
Specialized integrated circuits (ICs) or chips are designed to carry out specific functions. This category is where you’ll find addressable switches, air core gauge drivers, audio video switches, authentication chips, automatic discharge, clock generators, color scanners, and many other miscellaneous types of integrated circuits that are used for various applications.
SelectionCharacteristics
DigiKey Programmable: For verified products, DigiKey can program/flash your compiled code or configuration variables prior to shipping. For unverified products, please inquire with ProgCent.Techs@digikey.com
Applications: Application is the type of equipment or environment the device will be used in, typically they are tested and rated by a third party to ensure certain minimum standards for the application they are intended for.
ProductExamples
| MFR PART # | PAM8904EGPR |
| DIGIKEY PART # | 31-PAM8904EGPRTR-ND - Tape & Reel (TR) |
| MANUFACTURER | Diodes Incorporated |
| DESCRIPTION | Piezo Sounder Driver W-QFN2020-12 (Type US) |
| MFR PART # | ATSHA204A-SSHDA-T |
| DIGIKEY PART # | ATSHA204A-SSHDA-TTR-ND - Tape & Reel (TR) |
| MANUFACTURER | Microchip Technology |
| DESCRIPTION | Authentication Chip 8-SOIC |
| MFR PART # | DS2401+ |
| DIGIKEY PART # | DS2401±ND |
| MANUFACTURER | Analog Devices Inc./Maxim Integrated |
| DESCRIPTION | Silicon Serial Number TO-92-3 |
| MFR PART # | FM31276-G |
| DIGIKEY PART # | 448-FM31276-G-ND |
| MANUFACTURER | Infineon Technologies |
| DESCRIPTION | Processor Companion 14-SOIC |
| MFR PART # | SM74611KTTR |
| DIGIKEY PART # | 296-35688-2-ND - Tape & Reel (TR) |
| MANUFACTURER | Texas Instruments |
| DESCRIPTION | Smart Bypass Diode DDPAK/TO-263-3 |
| MFR PART # | AGB64LV01-QC-E |
| DIGIKEY PART # | 681-1013-ND |
| MANUFACTURER | Amulet Technologies LLC |
| DESCRIPTION | Microcontroller 80-PQFP (14x20) |
