This Product Selection Guide contains information to help select products in the Application Specific Microcontrollers category on DigiKey.com
Application-specific microcontrollers are semiconductor devices that incorporate a processing unit (microprocessor), memory (EEPROM, EPROM, flash, SRAM, ROM, RAM, etc.), and some peripherals (clocks, converters, ports, timers, UARTS, etc.) into a single device. Applications include audio recorder/playback, authentication, automotive, battery monitor, BLDC controller, Bluetooth, embedded security, GPS, networking, and USB to name a few.
SelectionCharacteristics
DigiKey Programmable: For verified products, DigiKey can program/flash your compiled code or configuration variables prior to shipping. For unverified products, please inquire with ProgCent.Techs@digikey.com.
Applications: Application is the type of equipment or environment the device will be used in, typically they are tested and rated by a third party to ensure certain minimum standards for the application they are intended for.
Core Processor: Identifies the microprocessor or processor technology that serves as the primary computational engine for a board or device.
Program Memory Type: Indicates the non-volatile memory technology that is used for program storage and the capacity of that memory.
Controller Series: Describes which CPU core(s) that are being used in the deivce.
RAM Size: Indicates the amount of RAM (Random Access Memory) with which a device is equipped.
Interface: Indication of which interface(s) or protocol(s) are used by the device to communicate with other components in the system.
Number of I/O: Indicates the number of device pins that are capable of being used for general-purpose digital input/output functions.
Voltage - Supply: Typically represented by a range, this indicates the low and high voltage limits that one can expect in standard operation. Voltages outside this range may damage the device and other system components.
ProductExamples
| MFR PART # | STSPIN32F0251Q |
| DIGIKEY PART # | 497-STSPIN32F0251Q-ND |
| MANUFACTURER | STMicroelectronics |
| DESCRIPTION | 250 V THREE-PHASE CONTROLLER WIT |
| MFR PART # | SLM9670AQ20FW1311XTMA1 |
| DIGIKEY PART # | SLM9670AQ20FW1311XTMA1TR-ND - Tape & Reel (TR) |
| MANUFACTURER | Infineon Technologies |
| DESCRIPTION | INDUSTRIAL TPM SECURITY |
| MFR PART # | 15311R-1000 |
| DIGIKEY PART # | 1499-1045-ND |
| MANUFACTURER | Echelon Corporation |
| DESCRIPTION | IC TXRX POWER LINE 38TSSOP |
MediaLinks
Videos
TinyML: Getting Started with TensorFlow Lite for Microcontrollers
Intro to MicroPython – Maker.io Tutorial
Videos on Microcontrollers
Articles
Application-Specific MCUs Targeting Emerging Applications
Multicore Microcontrollers Drive Performance
Secure Microcontrollers Keep Data Safe
Product Training Modules
Product Training Module Search
Blogs
Functional Safety with Microcontrollers
Microcontrollers Design Safety-Critical Apps
Introduction to MicroPython (digikey.com)
TechForum
Implementing a Robust Microcontroller to FPGA SPI Interface: Part 1 - FPGA Challenges
Microcontroller Hardware Abstraction Layer (HAL) in Education
Effective interfacing between the sensor and the microcontroller
