This Product Selection Guide contains information to help select products in the Microcontrollers, Microprocessor, FPGA Modules category on DigiKey.com
Products in the modular embedded processor family integrate a microcontroller, microprocessor, digital signal processor, FPGA, or other such computational device together with support components such as memory, power management, timing, and other items necessary for their operation. They are suitable and intended for integration into an end product, and offer product developers access to modern computational and interface capabilities without the necessity of high-speed hardware design experience.
SelectionCharacteristics
Module/Board Type: Describes the overall configuration and function of the device.
Core Processor: Identifies the microprocessor or processor technology that serves as the primary computational engine for a board or device.
Co-Processor: Identifies an auxiliary/special-purpose computational engine featured on a module.
Speed: Indicate the clock frequency of the device. This directly influences the overall rate computations that can be done on the device.
Flash Size: Describes size and type of non-volatile memories available on the module.
RAM Size: Indicates the amount of RAM (Random Access Memory) with which a device is equipped.
Connector Type: Indicates the type(s) of connections the device incorporates.
Size / Dimension: The physical dimensions of the device.
ProductExamples
| MFR PART # | SM-K26-XCL2GI |
| DIGIKEY PART # | 122-SM-K26-XCL2GI-ND |
| MANUFACTURER | AMD |
| DESCRIPTION | Zynq® UltraScale+™ Kria™ Embedded Module ARM® Cortex®-A53 Arm® Cortex®-R5F 533MHz, 1.333GHz 4GB 16GB eMMC, 64MB QSPI |
| MFR PART # | SOMIMX8MNS-10-29C0DMCR |
| DIGIKEY PART # | 460-SOMIMX8MNS-10-29C0DMCR-ND |
| MANUFACTURER | Beacon EmbeddedWorks |
| DESCRIPTION | i.MX 8M Nano Embedded Module ARM® Cortex®-A53, ARM® Cortex™-M7 1.5GHz, 750MHz 1GB 8GB |
| MFR PART # | MODM7AE70-200IR |
| DIGIKEY PART # | 528-MODM7AE70-200IR-ND |
| MANUFACTURER | NetBurner Inc. |
| DESCRIPTION | - Embedded Module ARM® Cortex®-M7 300MHz 8MB 2MB |
