This Product Selection Guide contains information to help select products in the System On Chip (SoC) category on DigiKey.com
Devices in the System-on-Chip family combine on one device substrate several computing system components which traditionally would be implemented as separate devices, such as a general-purpose microprocessor, an FPGA co-processor, and a graphics controller for generation of display data. While limited amounts of data storage resources may also be incorporated, the provision of an interface to external storage devices is typical.
SelectionCharacteristics
Architecture: Indicates functional blocks that are incorporated into a device.
Core Processor: Identifies the microprocessor or processor technology that serves as the primary computational engine for a board or device.
Flash Size: Amount of non-volatile memory available in the SoC.
RAM Size: Amount of RAM (Random Access Memory) available in the SoC.
Peripherals: Enumerates common functions that are incorporated within a device or specifically provisioned for by a device’s architecture.
Connectivity: Enumerates the standardized communication protocols for which a device provides hardware support.
Speed: Indicate the clock frequency of the device. This directly influences the overall rate computations that can be done in the device.
Primary Attributes: Provides a brief description of the programmable logic core incorporated in a device.
ProductExamples
| MFR PART # | SC-20100S-A |
| DIGIKEY PART # | 1711-SC-20100S-A-ND |
| MANUFACTURER | GHI Electronics, LLC |
| DESCRIPTION | ARM Cortex-M7 System On Chip (SOC) IC - 480MHz 100-LQFP (14x14) |
| MFR PART # | A2F200M3F-FGG256I |
| DIGIKEY PART # | 1100-1233-ND |
| MANUFACTURER | Microchip Technology |
| DESCRIPTION | ARM® Cortex®-M3 System On Chip (SOC) IC SmartFusion® ProASIC®3 FPGA, 200K Gates, 4608 D-Flip-Flops 80MHz 256-FPBGA (17x17) |
| MFR PART # | XCZU1CG-2UBVA494I |
| DIGIKEY PART # | 122-XCZU1CG-2UBVA494I-ND |
| MANUFACTURER | AMD |
| DESCRIPTION | Dual ARM® Cortex®-A53 MPCore™ with CoreSight™, Dual ARM®Cortex™-R5 with CoreSight™ System On Chip (SOC) IC Zynq® UltraScale+™ MPSoC CG Zynq®UltraScale+™ FPGA, 81K+ Logic Cells 533MHz, 1.333GHz 494-FCBGA (14x14) |
MediaLinks
Videos
Videos on SoC
Articles
MCUs or SoC FPGAs? Which is the Best Solution?
BLE 5.2 SoCs Offer Advanced Features
Using FPGA SoCs for Real-Time Systems
More articles on SoC
Product Training Modules
Video/Audio System on Chip (SOC) Codec Modules
Customizable Arm®-Based SoC
Single-Mode Bluetooth Smart SoC Solution
Blogs
Sensor Fusion Improves Battery Management Systems
DigiKey’s RISC-V Reference Guide Introduction
Use a Complete Wi-Fi/Bluetooth Combo Module
More Blogs on SoC
TechForum
TechForum search results for SoC
