This Product Selection Guide contains information to help select products in the DSP (Digital Signal Processors) category on DigiKey.com
Digital signal processors are devices similar to microprocessors or microcontrollers, but distinguished by having internal architectures that are adapted for the continuous execution of algorithms dominated by multiplication and addition operations performed on a continuous stream of data, as contrasted with algorithms that are dominated by conditional logic or a multiplicity of concurrent processes. They are commonly used in applications such as audio or video signal processing.
SelectionCharacteristics
Interface: Indication of which interface(s) or protocol(s) are used by the device to communicate with other components in the system.
Clock Rate: Indicates maximum rated operating frequency of processor core.
Non-Volatile Memory: Indicates the amount and type of Non-Volatile Memory being used in the item.
On-Chip RAM: Indicates the amount of On-Chip RAM memory the item has.
Voltage - I/O: Characterizes the supply voltage range over which a device’s external interface functions are specified to operate.
Voltage - Core: The nominal supply voltage required for a processor’s internal logic functions.
ProductExamples
| MFR PART # | ADAU1701JSTZ |
| DIGIKEY PART # | 505-ADAU1701JSTZ-ND |
| MANUFACTURER | Analog Devices Inc. |
| DESCRIPTION | IC AUDIO PROC 2ADC/4DAC 48-LQFP |
| MFR PART # | AK7755EN |
| DIGIKEY PART # | 974-1070-2-ND - Tape & Reel (TR) |
| MANUFACTURER | Asahi Kasei Microdevices/AKM |
| DESCRIPTION | IC DSP CODEC 24BIT 36QFN |
| MFR PART # | TMS320C28346ZFEQ |
| DIGIKEY PART # | 296-32740-ND |
| MANUFACTURER | Texas Instruments |
| DESCRIPTION | IC DSP FLOATING POINT 256BGA |
MediaLinks
Videos
5V CAN LIN Starter Kit for Digital Signal Controllers (DSCs)
Articles
Merging MCU and DSP Functionality for Processing
DSP-Enabled MCUs Tackle Audio and Speech Tasks
Integrated DSP RISC Cores Set Performance Ceiling
Blogs
What in the World is Digital Signal Processing?
