This Product Selection Guide contains information to help select products in the Controllers category on DigiKey.com
Memory controller products are used to mediate interactions between a device such as a microcontroller and external data storage devices, with the exact functionality offered varying depending on the intended use case. For example, some provide the necessary power monitoring and management facilities to allow conversion of a volatile memory to non-volatile, others provide a bridge between a standard USB interface and an array of NAND flash devices, while others provide functions that differ in other ways.
SelectionCharacteristics
Controller Type: The specific type or category of memory controller integrated into the IC.
Voltage - Supply: Typically represented by a range, this indicates the low and high voltage limits which one can expect standard operation. Voltages outside this range may damage the device and other system components.
Mounting Type : Indicates how the device is attached.
| MFR PART # | MXD1210CPA+ |
| DIGIKEY PART # | MXD1210CPA±ND |
| MANUFACTURER | Analog Devices Inc./Maxim Integrated |
| DESCRIPTION | IC CNTRLR NVRAM 8-DIP |
| MFR PART # | BQ2201SN-N |
| DIGIKEY PART # | 296-47692-ND |
| MANUFACTURER | Texas Instruments |
| DESCRIPTION | IC SRAM NONVOLATILE CNTRLR 8SOIC |
| MFR PART # | BQ2204ASNTR |
| DIGIKEY PART # | BQ2204ASNTR-ND |
| DESCRIPTION | IC X4 SRAM NONVOL CTRLR 16-SOIC |
