This Product Selection Guide contains information to help select products in the Power Supply Controllers, Monitors category on DigiKey.com
A semiconductor device that is designed to monitor and/or control voltage rails within a circuit.
SelectionCharacteristics
DigiKey Programmable: For verified products, DigiKey can program/flash your compiled code or configuration variables prior to shipping. For unverified products, please inquire with ProgCent.Techs@digikey.com
Applications: Application is the type of equipment or environment the device will be used in, typically they are tested and rated by a third party to ensure certain minimum standards for the application they are intended for.
Voltage - Input: Typically represented by a range, this indicates the low and high voltage limits which one can expect standard operation. Voltages outside this range may damage the device and other system components.
Voltage - Supply: Typically represented by a range, this indicates the low and high voltage limits which one can expect standard operation. Voltages outside this range may damage the device and other system components.
Current - Supply: This represents the maximum current to which a device will meet its given specifications. Exceeding this current may damage the device and/or other system components.
Package / Case: Indicates the type of protective case used on an electronic component to allow easy handling, installation, and protection. This selection was determined to be the closest industry standard applicable to the suppliers device packaging. Typically it is best to check the actual dimensions from the datasheet rather than depend on this terminology when designing your circuit.
ProductExamples
| MFR PART # | LTC2954CTS8-2#TRPBF |
| DIGIKEY PART # | 505-LTC2954CTS8-2#TRPBFTR-ND - Tape & Reel (TR) |
| MANUFACTURER | Analog Devices Inc. |
| DESCRIPTION | Power Supply Controller Push Button, On/Off Controller TSOT-23-8 |
| MFR PART # | ISL28023FR60Z-T7A |
| DIGIKEY PART # | ISL28023FR60Z-T7ATR-ND - Tape & Reel (TR) |
| MANUFACTURER | Renesas Electronics America Inc |
| DESCRIPTION | Power Supply Controller Digital Power Monitor 24-QFN (4x4) |
| MFR PART # | UC3844AN |
| DIGIKEY PART # | 296-11291-5-ND |
| MANUFACTURER | Texas Instruments |
| DESCRIPTION | Power Supply Controller PWM Controller 8-PDIP |
| MFR PART # | NCP4306DAHZZAASNT1G |
| DIGIKEY PART # | NCP4306DAHZZAASNT1GOSTR-ND - Tape & Reel (TR) |
| MANUFACTURER | onsemi |
| DESCRIPTION | Power Supply Controller Secondary-Side Controller, Synchronous Rectifier 6-TSOP |
MediaLinks
Videos
Videos on Power Supply Controllers
Articles
Articles on Power Supply Controllers
Product Training Modules
Prioritized PowerPath™ Controllers - Analog Devices
LT3757 and LT3758 - ADI
Blogs
Blogs on Power Supply Controllers
TechForum
TechForum posts on Power Supply Controllers
