This Product Selection Guide contains information to help select products in the Integrated Circuits (ICs) Kits category on DigiKey.com
Pre-packaged sets of surface mount and through-hole integrated circuits (ICs) for evaluation, demonstration and experimentation. Cardboard and plastic kit boxes include digital isolators, high-side drivers, logic, memory, microcontrollers, RF, switches, multiplexors, demultiplexers, transceivers, and translators. Kits are available according to the number of values and the quantity of each value required.
SelectionCharacteristics
Kit Type: A general description of the function and contents of the kit.
Quantity: Indicates the number of pieces contained in the kit.
Kit Contents: A detailed description of what the kit comes with.
Mounting Type: Indicates how the devices in the kit can be attached.
ProductExamples
| MFR PART # | MAXESSENTIAL02EP# |
| DIGIKEY PART # | 175-MAXESSENTIAL02EP#-ND |
| MANUFACTURER | Analog Devices Inc./Maxim Integrated |
| DESCRIPTION | Integrated Circuit Kit 9 Pieces (9 Values - 1 Each) Surface Mount |
| MFR PART # | SAMPLES-AUTOPMIC |
| DIGIKEY PART # | 497-17563-ND |
| MANUFACTURER | STMicroelectronics |
| DESCRIPTION | Integrated Circuit Kit High Side Driver Surface Mount |
| MFR PART # | SI826XSAMP-KIT |
| DIGIKEY PART # | 336-2414-ND |
| MANUFACTURER | Skyworks Solutions Inc. |
| DESCRIPTION | Integrated Circuit Kit Digital Isolator Surface Mount, Through Hole |
