This Product Selection Guide contains information to help select products in the Discrete Assortment Kits category on DigiKey.com
Pre-packaged sets of surface mount and through-hole discrete semiconductors for evaluation, demonstration and experimentation. Book, box and plastic bin boxes with bin guides contain sets of MOSFETs, rectifier diodes, transistors or Zener diodes. Kits are available according to the number of values and the quantity of each value required.
SelectionCharacteristics
Kit Type: A general description of the function and contents of the kit.
Quantity: Indicates the number of pieces contained in the kit.
Mounting Type: Indicates how the devices in the kit can be attached.
ProductExamples
| MFR PART # | CD-LAB2 |
| DIGIKEY PART # | CD-LAB2-ND |
| MANUFACTURER | Bourns Inc. |
| DESCRIPTION | Rectifier Diode Kit 320 Pieces (32 Values - 10 Each) Surface Mount |
| MFR PART # | DIODEKIT101 |
| DIGIKEY PART # | 4491-DIODEKIT101-ND |
| MANUFACTURER | Lumimax Optoelectronic Technology |
| DESCRIPTION | Rectifiers, Schottky Diodes, Switching Diodes Kit 80 Pieces (16 Values - 5 Each) Surface Mount, Through Hole |
| MFR PART # | ZENER KIT |
| DIGIKEY PART # | 641-1426-ND |
| MANUFACTURER | Comchip Technology |
| DESCRIPTION | Zener Kit 300 Pieces (30 Values - 10 Each) Surface Mount |
| MFR PART # | NTEKCOM1 |
| DIGIKEY PART # | 2368-NTEKCOM1-ND |
| MANUFACTURER | NTE Electronics, Inc |
| DESCRIPTION | Design Kit Assorted |
