Wire Tie Guns and Accessories
This Product Selection Guide contains information to help select products in the Wire Tie Guns and Accessories category on DigiKey.com
Wire Tie Guns and accessories are devices used to tighten and/or cut wire tie fasteners. Wire tie-guns can be automatic or manual, flush cut or twist cut-off, stationary head or rotating head, and have adjustable tension for the ties whether nylon or steel. Some of the series include BARB-TY, Contour-Ty, Dome-Top, EVO, Mark 7 &9, Milwaukee, MKP, MT, Pan-Steel, RT, ServiceGrade, TytonTwister, UNIFOX, WIT, and WSM.
SelectionCharacteristics
Type: The type, style, or nature of the accessory.
Features: These are different capabilities or properties of the device such as adjustable tension, ergonomic, or flushmount.
ProductExamples
MFR PART # ST2MT
DIGIKEY PART # 298-1106-ND
MANUFACTURER Panduit Corp
DESCRIPTION Tool Gun For Pan-Steel® MLT, MLTC, MLTFC and MLTDH; Standard, Light Heavy, Heavy and Extra-Heavy Ties
DATASHEET Click Here
MFR PART # AL-900
DIGIKEY PART # 2162-AL-900-ND
MANUFACTURER Advanced Cable Ties, Inc.
DESCRIPTION Tool Gun For Cable Ties 100-300 lb
MFR PART # WIT-1
DIGIKEY PART # RPC1638-ND
MANUFACTURER Essentra Components
DESCRIPTION Tool Gun For WIT-18 through -50 Ties
MFR PART # 86571
DIGIKEY PART # 86571-ND
MANUFACTURER Klein Tools, Inc.
DESCRIPTION Tool Strapping Tool For Cable Ties up to 0.472" (12.00mm) Width
MFR PART # KRT2BLD
DIGIKEY PART # 298-21766-ND
DESCRIPTION Tool Accessory, Blade For Pan-Steel® BT2HT and RT2HT Installation Tools
MediaLinks
Videos
MG-1300 and MG-1400 Cable Tie removal Tool
Panduit Ergonomic Cable Tie Installation Hand Tools
Wire Tie Gun for Nylon Cable Ties
Wire Tie Gun for Metal Cable Ties
If you have any general questions on the specifications for selecting Wire Tie Guns and Accessories, please reply using the button below. If you have questions on specific Wire Tie Guns and Accessories please post those questions in the Tools category.
