This Product Selection Guide contains information to help select products in the Cable Ties - Holders and Mountings category on DigiKey.com
Cable Tie Holders and Mountings devices are designed to hold wire ties securely to another item. The types are dual opening, multiple opening, quad opening, signal opening, standard, triple opening, and 2-dual opening with the mounting types being adhesive, cable tie, clip on, edge mount, epoxy, magnetic, masonry screw, push in, push mount, rivet, screw, stud, staple, tie mount, torque mount, and weld stud mount.
SelectionCharacteristics
Type: Defines the primary construction style of the device, indicating which type of part it is and determining its general usage.
Size / Dimension: The physical dimensions of the device. Typically given in Length by Width by Height, in Inches (Millimeters).
Material: Indicates the material composition of the device.
Color: The dominant color of the device.
ProductExamples
| MFR PART # | PUM-071-C30 |
| DIGIKEY PART # | 298-10238-ND |
| MANUFACTURER | Panduit Corp |
| DESCRIPTION | Single Opening Cable Tie Holder Black Push In - Ribbed Shaft |
| MFR PART # | 151-01632 |
| DIGIKEY PART # | 1436-1933-ND |
| MANUFACTURER | HellermannTyton |
| DESCRIPTION | Quad Opening Cable Tie Holder Black Adhesive |
| MFR PART # | TMS001A |
| DIGIKEY PART # | RPC5518-ND |
| MANUFACTURER | Essentra Components |
| DESCRIPTION | Dual Opening Cable Tie Holder Natural Screw, #6 (M3) |
| MFR PART # | AL-MPA-750-0-C |
| DIGIKEY PART # | 2162-AL-MPA-750-0-C-ND |
| MANUFACTURER | Advanced Cable Ties, Inc. |
| DESCRIPTION | Quad Opening Cable Tie Holder Black Adhesive, Screw, #4 |
MediaLinks
Videos
Cable Tie Video Content
Articles
Selecting the Right Cable Tie
Blogs
Stainless Steel Cable Ties in Harsh Environments
Product Training Modules
Cable Ties and Accessories - Essentra Components
