This Product Selection Guide contains information to help select products in the Accessories category on DigiKey.com
Supplementary items used with other devices in this category.
SelectionCharacteristics
Accessory Type: The type, style, or nature of the accessory.
For use With/Related Products: Defines other part types, numbers, or series with which this product is designed to be used.
Material: Indicates the material composition of the device.
Features: These are different capabilities or properties of the device such as 0.100" Pitch, 0.75" Bundle Diameter, or NPT 1" Thread.
ProductExamples
| MFR PART # | 2583720000 |
| DIGIKEY PART # | 281-3840-ND |
| MANUFACTURER | Weidmüller |
| DESCRIPTION | Sealing Frame Set For |
| MFR PART # | CR2-M |
| DIGIKEY PART # | 298-14328-ND |
| MANUFACTURER | Panduit Corp |
| DESCRIPTION | Connector Ring For M, I, S Ties |
| MFR PART # | 28771.4 |
| DIGIKEY PART # | 2080-28771.4-ND |
| MANUFACTURER | Conta-Clip, Inc. |
| DESCRIPTION | Thread Adapter For |
| MFR PART # | ATPA-121212B |
| DIGIKEY PART # | 2124-ATPA-121212B-ND |
| MANUFACTURER | Fraenkische USA, LP |
| DESCRIPTION | Tubing - T Joiner For Fiplock® Corrugated Conduit |
| MFR PART # | JDAE12PA7035 |
| DIGIKEY PART # | 2291-JDAE12PA7035-ND |
| MANUFACTURER | Jacob GmbH |
| DESCRIPTION | Breather Plug For Cable Entry Opening |
| MFR PART # | 1411207 |
| DIGIKEY PART # | 277-18061-ND |
| MANUFACTURER | Phoenix Contact |
| DESCRIPTION | Counter Nut For M20 Thread - Cable Glands |
| MFR PART # | OFCG-16 |
| DIGIKEY PART # | RPC1584-ND |
| MANUFACTURER | Essentra Components |
| DESCRIPTION | Bend Radius Guide For OFCC-16A-RT Optical Fiber Coiling Clip |
| MFR PART # | 596-00191 |
| DIGIKEY PART # | 596-00191-ND |
| MANUFACTURER | HellermannTyton |
| DESCRIPTION | Legend Base For Labels |
