This Product Selection Guide contains information to help select products in the Wire Ducts, Raceways - Accessories category on DigiKey.com
Accessories for Wire Ducts and Raceways are parts designed to help hang, modify, fasten or complete the wire duct/raceway. The accessory types are adapter, alarm box, brackets, clips, communication pole assembly, connector kit, corner, DIN rail fastener, duct, electrical box, extension box, fan or fixture box, fastener, fiber spool bracket, fittings, floor guard, hanging box, installation tool, junction box, mounting base, outlet box, power box, reducer, rivet, wallplate, and work station outlet.
SelectionCharacteristics
Accessory Type: The type, style, or nature of the accessory.
Color: The dominant color of the product.
ProductExamples
| MFR PART # | RAF10WH-X |
| DIGIKEY PART # | 298-12417-ND |
| MANUFACTURER | Panduit Corp |
| DESCRIPTION | Connector Fitting - Right Angle (R/A) For Panduit Duct Type LD, LDP and CD10 |
| MFR PART # | TSRPI-RB |
| DIGIKEY PART # | 1436-2504-ND |
| MANUFACTURER | HellermannTyton |
| DESCRIPTION | Connector Junction Box Round - Power Rated, Base and Cover For TSRP Power Rated Surface Raceway |
| MFR PART # | 3240284 |
| DIGIKEY PART # | 277-7723-ND |
| MANUFACTURER | Phoenix Contact |
| DESCRIPTION | Connector Fitting - Wire Retainer, Clip In For For All PVC Wiring Duct Types |
| MFR PART # | DS1 |
| DIGIKEY PART # | 298-10486-ND |
| DESCRIPTION | Connector Duct Sealing Compound For For All PVC Wiring Duct Types |
| MFR PART # | T70WC2IW |
| DIGIKEY PART # | T70WC2IW-ND |
| DESCRIPTION | Connector Work Station Outlet Center For Panduit Duct Type T70 |
| MFR PART # | TSR1W-21-1 |
| DIGIKEY PART # | TSR1W-21-1-ND |
| DESCRIPTION | Connector Fitting - Tee Cover For TSR1 3/4" Low Voltage Surface Raceway |
