This Product Selection Guide contains information to help select products in the Wire Ducts, Raceway Covers category on DigiKey.com
Accessory covers designed for use with specific wire duct and raceway conduits to completely enclose a physical pathway for electrical wiring. Covers are snap-in mount and may include a hinge or protective film. Wire duct and raceway covers are differentiated by height, width, length, manufacturer series and color.
SelectionCharacteristics
Accessory Type: The type, style, or nature of the cover.
Height: Indicates the overall height of the cover.
Width: Indicates the overall width of the cover.
Length: Indicates the overall length of the cover.
Color: The dominant color of the cover.
ProductExamples
MFR PART # | C1.5LG6 |
DIGIKEY PART # | 298-12046-ND |
MANUFACTURER | Panduit Corp |
DESCRIPTION | Cover - Wire Duct, Snap In Gray, Light 6.000’ (1828.80mm, 72.00") |
DATASHEET | Click Here |
MFR PART # | 181-91002 |
DIGIKEY PART # | 1436-2616-ND |
MANUFACTURER | HellermannTyton |
DESCRIPTION | Cover - Wire Duct, Snap In Blue 6.000’ (1828.80mm, 72.00") |
MFR PART # | FRSHC4YL6 |
DIGIKEY PART # | FRSHC4YL6-ND |
DESCRIPTION | Cover - Wire Duct, Snap In Hinged Yellow 6.000’ (1828.80mm, 72.00") |
MFR PART # | T70FV2IW |
DIGIKEY PART # | T70FV2IW-ND |
DESCRIPTION | Cover, Snap-On, Sloped, Horizontal - 2-Port White, Off 4.500" (114.30mm) |
