This Product Selection Guide contains information to help select products in the Sensor Cable Accessories category on DigiKey.com
Sensor Cable Accessories are supportive parts for use with sensor cables. The accessory types are adapter, cap (cover)/sealing, gasket, screw, seal, short circuit connector, terminator, valve connector, or washer/sealing.
SelectionCharacteristics
Accessory Type: The type, style, or nature of the accessory.
ProductExamples
| MFR PART # | 1212020001 |
| DIGIKEY PART # | WM21613-ND |
| MANUFACTURER | Molex |
| DESCRIPTION | TYPE B IND BLACK NBR GASKET |
| MFR PART # | GDM 3011 RF-1 |
| DIGIKEY PART # | 1794-1210-ND |
| MANUFACTURER | Hirschmann |
| DESCRIPTION | SS SCREW FOR GMD SERIES |
| MFR PART # | WCCS-50-M |
| DIGIKEY PART # | 2740-WCCS-50-M-ND |
| MANUFACTURER | SeaHawk |
| DESCRIPTION | CABLE SEPARATOR - SC-C |
