This Product Selection Guide contains information to help select products in the HVAC Parts and Accessories category on DigiKey.com
SelectionCharacteristics
Type: The type, style, or nature of the accessory.
Height (Inches): Indicates the overall height of the device.
Length (Inches): Indicates the overall length of the device.
Width (Inches): Indicates the overall width of the device.
Material: Indicates the material composition of the device.
Voltage: Typically this rating indicates the nominal amount of voltage you would expect the device to draw during normal operation.
Current Rating (Amps): This rating indicates the nominal amount of current you would expect the device to draw during normal operation.
Color: The dominant color of the device.
Programmable: Indicates whether the item is programmable by the user.
ProductExamples
| MFR PART # | P500_F |
| DIGIKEY PART # | 3005-P500_F-ND |
| MANUFACTURER | PURO²XYGEN |
| DESCRIPTION | V Air Purifier Replacement Filter |
| MFR PART # | PH950_WF |
| DIGIKEY PART # | 3005-PH950_WF-ND |
| MANUFACTURER | Turonic |
| MFR PART # | TC500A-N |
| DIGIKEY PART # | 3769-TC500A-N-ND |
| MANUFACTURER | Honeywell |
| DESCRIPTION | V |
