This Product Selection Guide contains information to help select products in the Air Conditioners category on DigiKey.com
SelectionCharacteristics
Type: The type, style, or nature of the accessory.
BTU’s: Indicates the amount of heat the item is rated to thermally transfer.
Cooling Square Feet: The amount of space the unit is able to nominally cool.
Voltage: Typically this rating indicates the nominal amount of voltage you would expect the device to draw during normal operation.
Depth: Indicates the overall depth of the device.
Width (Inches): Indicates the overall width of the device.
Height: Indicates the overall height of the device.
Frequency: The frequency the unit is rated to be powered by.
Material: Indicates the material composition of the device.
Cord Length: Indicates the length of the cord, if applicable.
Color: The dominant color of the device.
Approval Agency: An indication that the product meets the minimum safety standards of an approving agency. These agencies are either government entities or private third-party labs that protect consumer safety.
ProductExamples
| MFR PART # | GPC05AP-A3NNA1A |
| DIGIKEY PART # | 4036-GPC05AP-A3NNA1A-ND |
| MANUFACTURER | TOSOT |
| DESCRIPTION | 8000BTU 250Sq. Ft Portable Air Conditioner |
| MFR PART # | GPC05AK-A3NNA1C |
| DIGIKEY PART # | 4036-GPC05AK-A3NNA1C-ND |
| DESCRIPTION | 8000BTU 300Sq. Ft Portable Air Conditioner |
| MFR PART # | GPC08AO-A3NNA1A |
| DIGIKEY PART # | 4036-GPC08AO-A3NNA1A-ND |
| DESCRIPTION | 12000BTU 450Sq. Ft Portable Air Conditioner |
