This Product Selection Guide contains information to help select products in the Food Storage and Preparation category on DigiKey.com
SelectionCharacteristics
Type: The type, style, or nature of the product.
Width (Inches): Indicates the overall width of the product.
Height (Inches): Indicates the overall height of the product.
Depth (Inches): Indicates the overall depth of the product.
Material: Indicates the material composition of the product.
Voltage: The nominal voltage the equipment is designed to be powered by.
Current Rating (Amps): This rating indicates the nominal amount of current you would expect the device to draw during normal operation.
Temperature Range: Recommended operating temperature, typically given in a range or as a maximum. Exceeding these temperatures may affect performance or damage the device and other system components.
Capacity (Cu. Ft.): The amount of material the container is able to hold/store.
Approval Agency: An indication that the product meets the minimum safety standards of an approving agency. These agencies are either government entities or private third-party labs that protect consumer safety.
ProductExamples
| MFR PART # | ECH70024S |
| DIGIKEY PART # | 3608-ECH70024STB-ND - Tape & Box (TB) |
| MANUFACTURER | Ecohouzng |
| DESCRIPTION | V Refrigerator |
| MFR PART # | POP B |
| DIGIKEY PART # | 4692-POPB-ND |
| MANUFACTURER | 5 Core Inc |
| DESCRIPTION | V Popcorn Machine |
| MFR PART # | 332008-5218 |
| DIGIKEY PART # | 3539-332008-5218-ND |
| MANUFACTURER | MFG Tray |
| DESCRIPTION | V Fiberglass Service Tray |
