This Product Selection Guide contains information to help select products in the Miscellaneous category on DigiKey.com
SelectionCharacteristics
Type: The type or nature of the product.
Style: Further describes the type of product.
Length (Inches): Indicates the overall length of the product.
Width (Inches): Indicates the overall width of the product.
Height (Inches): Indicates the overall height of the device.
Outer Diameter: Indicates the outer diameter of the product.
Voltage: Typically represented by a range, this indicates the low and high voltage limits which one can expect standard operation. Voltages outside this range may damage the device and other system components.
Current Rating (Amps): Typically this represents the maximum current to which a device will meet its given specifications. Exceeding this current may damage the device and/or other system components.
Color: The dominant color of the product.
Package Quantity: Indicates the number of items included with purchase.
ProductExamples
| MFR PART # | 249CP41-RP |
| DIGIKEY PART # | 3539-249CP41-RP-ND |
| MANUFACTURER | Global Industrial |
| DESCRIPTION | For Use With |
| MFR PART # | SEQCM708CH |
| DIGIKEY PART # | 3608-SEQCM708CHTB-ND - Tape & Box (TB) |
| MANUFACTURER | SeqCam |
| DESCRIPTION | Security Camera For Use With |
| MFR PART # | GS MUSHROOM |
| DIGIKEY PART # | 4692-GSMUSHROOM-ND |
| MANUFACTURER | 5 Core Inc |
| DESCRIPTION | Garden Patio Speaker For Use With |
