This Product Selection Guide contains information to help select products in the Solid State Lighting Connector Accessories category on DigiKey.com
Products in the solid-state lighting connector family are ancillary to or supportive of interconnect products that are designed with LED-based illumination applications in mind. The precise functions served by these products vary, but are generally related to providing supplemental electrical insulation or mechanical retention of some form.
SelectionCharacteristics
Accessory Type: The type, style, or nature of the accessory.
Specifications: This selection indicates the attributes which expound on a product’s abilities, but are not a standard attribute universal to this product family.
Material: Indicates the material composition of the device.
ProductExamples
MFR PART # | AC 164 BC/ 3 WS |
DIGI-KEY PART # | 2098-AC164BC/3WS-ND |
MANUFACTURER | Adels-Contact |
DESCRIPTION | Connector Fastening Clip For AC 164 Series |
DATASHEET | Click Here |
MFR PART # | 293658-1 |
DIGI-KEY PART # | A116653-ND |
MANUFACTURER | TE Connectivity AMP Connectors |
DESCRIPTION | Connector Contact Lock, Positioner For Contacts |
MFR PART # | 2332473-1 |
DIGI-KEY PART # | 17-2332473-1-ND |
DESCRIPTION | Connector Seal For |
