This Product Selection Guide contains information to help select products in the Solid State Lighting Connector Assemblies category on DigiKey.com
Products in the solid-state lighting connector family are interconnect products designed and marketed with particular focus on the needs of LED-based illumination applications. In general, this implies a focus on low product and assembly costs, predominantly for wire-to-board applications with relatively low mating cycle life expectancies and current capacities of a few amperes or less.
SelectionCharacteristics
Style: Indicates the general connection type/method being used.
Connector Type: Indicates the style and configuration of the device.
Number of Positions: Indicates the number of distinct conductors presented at a connector’s mating interface and the number of electrical contact points present within a connector.
Termination: Selection of termination style used to connect the device to a system, such as clamp, IDC, or solder.
Pitch: Indicates the center-to-center spacing between adjacent pins.
Fastening Type: The mating retention mechanism employed by the device.
Features: These are different capabilities or properties of the device such as board guide, keying, or cover.
Housing Color: The dominant color of the housing of the device.
Wire Gauge: The wire size or size range with which a product is designed for use, typically expressed in terms of American Wire Gauge.
Contact Material: Indicates the material composition of the contacts of the device.
Contact Finish: Indicates the finish/plating material applied to the contacts of the device.
Housing Material: Indicates the material composition of the housing of the device.
ProductExamples
| MFR PART # | 2038638103 |
| DIGIKEY PART # | WM17990TR-ND - Tape & Reel (TR) |
| MANUFACTURER | Molex |
| DESCRIPTION | SSL Connector 1 Position Receptacle, Poke-In Wire Board to Cable/Wire Solder |
| MFR PART # | SMDFLAT 345/ 2 WS |
| DIGIKEY PART # | 2098-SMDFLAT345/2WSTR-ND - Tape & Reel (TR) |
| MANUFACTURER | Adels-Contact |
| DESCRIPTION | SSL Connector 2 Position Receptacle, Poke-In Wire Board to Cable/Wire 0.157" (4.00mm) Solder |
| MFR PART # | LEAR-02V-S |
| DIGIKEY PART # | 455-2573-ND |
| MANUFACTURER | JST Sales America Inc. |
| DESCRIPTION | SSL Connector 2 Position Receptacle Housing for Socket Contact Board to Cable/Wire 0.071" (1.80mm) Crimp |
| MFR PART # | 2213189-3 |
| DIGIKEY PART # | A116140TR-ND - Tape & Reel (TR) |
| MANUFACTURER | TE Connectivity AMP Connectors |
| DESCRIPTION | SSL Connector 2 Position Receptacle, Poke-In Wire Board to Cable/Wire 0.130" (3.30mm) Solder |
| MFR PART # | 2060-952/028-000 |
| DIGIKEY PART # | 2946-2060-952/028-000-ND |
| MANUFACTURER | WAGO Corporation |
| DESCRIPTION | SSL Connector 2 Position Jumper Board to Board 0.157" (4.00mm) Poke-In |
MediaLinks
Videos
Releasable Poke-In Connectors
High Power Inverted Thru Board Connector
Articles
Connectors for Solid-State Lighting
Trends in Interconnect for LED Lighting Systems
Connectors Ease Installation Difficulties, Save Space in LED Lighting Designs
