This Product Selection Guide contains information to help select products in the Solid State Lighting Cables category on DigiKey.com
Solid state lighting cables are designed to work with specific solid state lighting equipment. There are a variety of connector options, color options, lengths, and features. Connector options are: blade and receptacle - multi position, outlet - mini HVL, plug - mini HVL, sockets, etc. Each of the connector types offer different position options.
SelectionCharacteristics
1st Connector: Indicates the style and configuration of the first connector used on the cable assembly.
2nd Connector: Indicates the style and configuration of the second connector used on the cable assembly.
Color: The dominant color of the cable assembly.
Length: The length of the cable assembly, this length may or may not include the connectors. Please consult the individual datasheets.
Features: These are different capabilities or properties of the device such as dimming or a latch lock.
ProductExamples
| MFR PART # | 2058943-1 |
| DIGIKEY PART # | A100192-ND |
| MANUFACTURER | TE Connectivity AMP Connectors |
| DESCRIPTION | SSL Cable Assembly Socket, 2 Position To Wire Leads Black, Red 6.25" (158.8mm) |
| MFR PART # | SSL12-J4LJ0-020A04 |
| DIGIKEY PART # | 1754-1184-ND |
| MANUFACTURER | Amphenol LTW |
| DESCRIPTION | SSL Cable Assembly Socket, 4 Position To Wire Leads Multiple 15.7" (400.0mm) |
| MFR PART # | 14830212 |
| DIGIKEY PART # | 2098-14830212-ND |
| MANUFACTURER | Adels-Contact |
| DESCRIPTION | SSL Cable Assembly Socket, 2 Position To Socket, 2 Position Black, Red |
| MFR PART # | 688014593 |
| DIGIKEY PART # | WM10332-ND |
| MANUFACTURER | Molex |
| DESCRIPTION | SSL Cable Assembly Plug, 2 Position To Plug, 2 Position White 1.81" (46.0mm) |
MediaLinks
Videos
Articles
Connectors for Solid-State Lighting
