This Product Selection Guide contains information to help select products in the LED Dot Matrix and Cluster category on DigiKey.com
Display Modules - LED Dot Matrix and Cluster units are Devices that use a light emitting diodes arranged in a matrix layout to provide visual graphics. Typically arranged in grid pattern with either the positive or negative terminal of the light emitting diode tied together as a common circuit node. Available in a variety of sizes and colors, these units can accept a wide range of interfaces from I2C, 8-bit parallel, serial and ASCII inputs.
SelectionCharacteristics
Millicandela Rating: Characterizes device brightness at the indicated test current or nominal input voltage.
Internal Connection: For devices lacking internal drive/control circuitry, describes internal connections that exist between the individual display elements.
Size / Dimension: The physical dimensions of the device. Typically length by width by height.
Color: Indcicates the color(s) emitted from the LED.
Configuration: Indicates the layout for the dot matrix.
Voltage - Forward (Vf) (Typ): The rated working voltage of a device, given as a range or as a maximum.
Interface: Indication of which interface(s) or protocol(s) are used by the device to communicate with other components in the system.
ProductExamples
| MFR PART # | LTP-757G |
| DIGIKEY PART # | 160-1002-ND |
| MANUFACTURER | Lite-On Inc. |
| DESCRIPTION | LED MATRIX 5X7 0.7" GREEN |
| MFR PART # | HCMS-2903 |
| DIGIKEY PART # | 516-1173-5-ND |
| MANUFACTURER | Broadcom Limited |
| DESCRIPTION | LED DISPLAY 5X7 4CHAR 3.8MM GRN |
| MFR PART # | 2276 |
| DIGIKEY PART # | 1528-2093-ND |
| MANUFACTURER | Adafruit Industries LLC |
| DESCRIPTION | 64X32 RGB LED MATRIX - 6MM PITCH |
MediaLinks
Videos
Videos on LED Dot Matrix
Articles
Articles on LED Dot Matrix
Product Training Modules
Product Training Modules on LED Dot Matrix
Blogs
Blogs on LED Dot Matrix
TechForum
TechForum posts on LED Dot Matrix
