This Product Selection Guide contains information to help select products in the Direct Digital Synthesis (DDS) category on DigiKey.com
Direct Digital Synthesis (DDS) is used to produce analog waveforms of different frequencies from a digital signal. It is used for frequency control in wireless systems that must sweep across a wide range. The master frequencies clocks are 5MHz, 16MHz, 16.776MHz, 25MHz, 50MHz, 75MHz, 125MHz, 180MHz, 200MHz, 250MHz, 300MHz, 400MHz, 500MHz, 1GHz, 2.5GHz, and 3GHz with a resolution of 10 b, 12 b, or 14 b.
SelectionCharacteristics
Resolution (Bits): The length of the digital word used by a device to represent a continuously variable physical quantity.
Master fclk: The maximum usable clock input frequency, as defined by the manufacturer.
Tuning Word Width (Bits): The width of the data word that controls output frequency.
Voltage - Supply: Typically represented by a range, this indicates the low and high voltage limits which one can expect standard operation. Voltages outside this range may damage the device and other system components.
Supplier Device Package: This is what the manufacturer calls the package of this device. They are manufacturer specific. It is typically best to use the actual dimensions from the datasheets rather than use this terminology when designing your circuit.
ProductExamples
| MFR PART # | AD9833BRMZ-REEL7 |
| DIGIKEY PART # | 505-AD9833BRMZ-REEL7TR-ND - Tape & Reel (TR) |
| MANUFACTURER | Analog Devices Inc. |
| DESCRIPTION | IC DDS 25MHZ 10BIT 10MSOP |
| MFR PART # | AD9957BSVZ-REEL |
| DIGIKEY PART # | AD9957BSVZ-REELTR-ND - Tape & Reel (TR) |
| DESCRIPTION | IC DDS 1GHZ 14BIT 100TQFP |
| MFR PART # | AD9913BCPZ |
| DIGIKEY PART # | 505-AD9913BCPZ-ND |
| DESCRIPTION | IC DDS 250MHZ 10BIT 32LFCSP |
MediaLinks
Articles
The Basics of Direct Digital Synthesizers (DDSs)
Fundamentals of Direct Digital Synthesis DDS
Basics of Direct Digital Synthesis
Product Training Modules
Direct Digital Synthesis Tutorial Series (2 of 7): The Accumulator
Direct Digital Synthesizer Tutorial Series (7 of 7): DDS in Action
Five Things to Know About DACs Part 5: Dynamic Performance
TechForum
Direct Digital Synthesis (DDS): Applications and Performance Insights
Maximum speed writing to a Direct Digital Synthesis (DDS)
How to Implement a PNT derived Pulse Per Second (PPS) External Trigger for an ADC and FPGA
